Using robotics to install PVC
« Back To RCS Lunch & Learn
June 2, 2023 at 12:36 p.m.
laurenwhite
Mark Brandon from Johns Manville talks about everything you want to know about PVC commercial roofing products, including robotics. Do you, or have you ever used a mechanical system to help install PVC membranes?
The RCS Lunch & Learn webinar series is dedicated to helping educate and inform about products, services and much more. It is an educational opportunity for the roofing industry as only RoofersCoffeeShop can do.
June 17, 2024 at 6:17 a.m.
finlaysu
We usually use fully adhered systems. I think they last longer and look better.
January 29, 2024 at 8:17 p.m.
NellyAurora
I am very interested. PVC films are commonly joined together through heat welding in order to form durable and waterproof connections.
June 29, 2023 at 11:54 p.m.
Anderecit71
PVC films are usually heat welded together to create strong and watertight seams. Automatic welding machines are often used to ensure uniform and precise seam joints. These machines use hot air or hot wedge technology to heat and melt the PVC film edges.
