Tile cuts at valleys
April 12, 2014 at 4:07 p.m.
Still lovin the pain
I am wondering if anyone else is as grateful as me for people that cut tile valleys so close that they dam up and cause leaks B) sure does keep me busy on the newer homes.
April 18, 2014 at 1:29 a.m.
One and two-piece mission tiles have to be fastened but they are a completely different animal. (I imagine you are just pulling our chains with the pic) Shingles, shakes, and slates have to be fastened too. In the old old days, back in the old country, they used to fasten stone slates with little pegs driven into holes in them. The Union generals felt that way about Nathan Bedford Forrest, too. They couldn't peg him and he was always slipping away to give them a new headache.
April 17, 2014 at 9:26 p.m.
What do you think, nails or no nails :)
April 16, 2014 at 9:52 a.m.
I forgot to mention that wind seems to slear off the valleys with the gutter screen. The water drips through, the leaves and needles dry out and the wind keeps it pretty clean. :)
I am surprised I didn't get flamed for it though. :P
April 14, 2014 at 9:51 p.m.
Yes, at first thought and as per common perception, is that an open valley allows for a more "free-flow", so-to-speak. However, after 30+ years and somewhere north of 150,000 squares of tile installed, we have found that a closed valley is far less problematic, both in cold climates, as well as heavy debris situations. The debris is going to collect either way. Just less-so w/closed valley.
April 14, 2014 at 8:13 a.m.
I've had some problematic slate roofs that were under pines and other nasty trees. You all know I like to think outside the box, even when the solution isn't in a book.
I open the valley to 5" or 6" depending on lenght, valley metal, and tile/slate shape. I install copper gutter screen in the valley. You know, what ever the situation dictates. The debris collects on top of the screen and on top of the slate/tile and can be swept off. The little bit that collects under the screen gets rinsed out with a hose. :)
April 14, 2014 at 7:53 a.m.
theroofmedic1
Closed valleys... Can keep a roofing contractor busy in repairs year around....
April 13, 2014 at 5:25 p.m.
On our way to the ski lifts, I walk briskly through the plaza in Beaver Creek, keeping a watchful eye above, as I know all those hundreds of rake tiles, 50' above on 8:12 + pitches, are held by a single 16d nail, (sometimes it's a sinker, to boot!)....no copper wire, no adhesive.....Every once in awhile one will come crashing down......I can't believe no-one's been killed.
April 13, 2014 at 12:44 p.m.
The ones that fall off are the rake tiles. That's about it. When you have a nine lb. tile interlocked in the field with its immediate neighbors and weighed down at the head by eighteen lbs of interlocking successors, it's quite a feat to get it out at all, even un-nailed. Earthquakes cause a building to "hop" but the "hopping" action combined with the pulling action you have to engage to remove one of those is not something Mother Nature is likely to duplicate. In a bad enough earthquake it is more likely that the entire overhang would fall off than the tile.
If it goes to court, that's when the dufus mindset gains the upper hand. "Tile not fastened properly... installer not properly trained ... judgement for the plaintiff." (or something of that order.)
Right or wrong, we wire them in the valleys. They can't fly off the roof but they can be moved around a bit. Maybe the spec is designed to appease Dade county types. We don't get uplift from winds over a hundred miles an hour. Maybe the right wind could get under them and peel them out of a valley. Tornado would do it. Don't have those here. All I know is I can get some nasty little blood-blisters while extracting tiles from the field even when I'm careful.
Don't want to have to use a cutting torch to open the hood and check the oil. God, I have a bad attitude. (and it just keeps getting worse)
April 13, 2014 at 12:16 p.m.
Its funny that you say that egg,because I still don't get fastening tile with a nail. I have yet to see a tile fall off of a roof because it wasn't nailed. I understand adhering them to the next tile for lack of a batt around a chimney or valley but a nail in them, not needed in my opinion. Unless your in California like me where there might be an earthquake but still. My comments are for one piece tile.
April 13, 2014 at 11:58 a.m.
Not exactly on-topic but I remember well when the law first changed on tile installation and the rule for fastening became "three up, three down, three in, three out." Try cleaning out a clogged valley when all the parts have been nailed down with a 10d fastener.
April 13, 2014 at 11:38 a.m.
IMO closed valleys work best overall.
In cold climates, ice can build-up in valleys, mixed with pine needles/debris as re-enforcing fiber, causing bothersome ice dams/ponding.
Temperate climates; Open valleys, again, create a great nesting spot for leaves/debris, whereas, otherwise, with a closed valley, the valley underneath remains relatively clear.
Of course, if some nucklehead leaves debris in the original construction, or doesn't prepare tile correctly, as wywoody mentioned, it's all a crap shoot.
Most tile roofs we run across here in the mountains of Colorado are ill-installed. The poor quality/dependency on underlayment mentality, during the last significant construction activity, are coming to fruition. It takes a decade or so for the underlayments to finally give up the ghost.
April 13, 2014 at 7:04 a.m.
uh.....I dunno....What would Chuck Norris do?
