tearing off shingles on ice and watershield
March 20, 2010 at 5:10 p.m.
WildBill
y'all ever had to tear off shingles that were put on directly over ice and watershield? We have had a one job where the shingles were just stuck in the i&w that we couldn't get them off. I'm just wondering if there are certian types of i&w to aviod or if it was just the hot weather that caused that problem. Maybe they will come off in cold weather. I havn't run accross it enough times to really know that it is a fact that the shingles won't come off.
I've got this new housing project job and the Arch has it specd that we install shingles directly on the i&w (the whole roof). I'm planning on using "Tarco" i&w because they are the cheapest ($32/roll). I've never used Tarco i&w either. We usually use Tamko stormguard but it was a good bit more and there is a lot of it.
I would hate to be the feller that has to tear-off these shingles down the road.
Would you bring this up to the Arch or just let it go and put the shingles on the way he says to put them on?
April 10, 2010 at 11:52 a.m.
jimAKAblue
minnesotaroofin Said: Yea i agrre probably even more so - I think it is all a marketing scam by the manufactures to make up for all the hack roofers out there who cannot install a roof without having back up protection -- in my opinion if the primary system fails the whole roof is toast. I have torn off more roofs than i can count with no felt or I & W that never had any problems until it got covered in a plastic bag - even the synthetic felts do not breathe very well.
As far as removing the decking to get the I&W off we typiciall just put a new layer over the top -- even some of the shingles are still stuck to it normally all the shingles except a 1 inch strip comes off and if you go back on with dimensionals you never even notice -- 3 tabs are a different story you can see a little variation where the stuck 1 inch strips wont come off.
For decades, I thought that "secondary roof protection" was overrated. Then I moved to Texas where the rain blows sideways. My first job here in Texas was a roof leak call. The water had damaged the drywall in the middle of their "great room". I went there confident that I'd find a leak near a chimney, vent or pipe. Nope...the leak was in the middle of a clear section of roof. There were no signs of entry point ANYWHERE. I finally decided that we had to take off shingles at the leak point to see what was happening. The result? The felt had been torn and folded upward exposing the wood deck. Water was blown up and under the shingles and entered in that one spot.
I fixed the felt, re-shingled and I checked two years later and they hadn't had any more leaks.
The roof was a 9/12. I think it had 25 yr 3 tab shingles.
I now believe that secondary weather barriers are necessary.
April 9, 2010 at 8:36 a.m.
soldierboy
Jed, you are so right! I wrapped a building 90 sq with a pool built inside. I had them sign a waiver, sure enough years later I get a call that it's leaking. Condensation from the pool couldn't escape.. LOL I warned them and they didn't listen. Now there stuck with it! :cheer:
April 8, 2010 at 10:11 p.m.
soldierboy
If I understand this correctly. Your putting ice and water shield on the entire roof surface? Tell me if I'm wrong but isn't ice and water shield also a vapor barrier? Won't that warp the plywood or OSB? I have seen a homeowner use it on his entire roof and what a mess two years later. He had us take of the shingles and wood. We only went up 4 ft. into the heated wall for him. He had two ft. overhangs. Anyway,good luck on the project. I would make them sign a waiver form first.
April 3, 2010 at 1:25 p.m.
robert
use rosin paper between the two very cheap and will most likely prevent them from bonding together
March 21, 2010 at 3:44 p.m.
2ndgen
WildBill Said: yall ever had to tear off shingles that were put on directly over ice and watershield? We have had a one job where the shingles were just stuck in the i&w that we couldnt get them off. Im just wondering if there are certian types of i&w to aviod or if it was just the hot weather that caused that problem. Maybe they will come off in cold weather. I havnt run accross it enough times to really know that it is a fact that the shingles wont come off.
I'd think that was a good thing that shingles would stick like glue to I&W. Imagine, if we can't get them off, how much harder a time the wind will.
Ive got this new housing project job and the Arch has it specd that we install shingles directly on the i&w (the whole roof). Im planning on using Tarco i&w because they are the cheapest ($32/roll). Ive never used Tarco i&w either. We usually use Tamko stormguard but it was a good bit more and there is a lot of it.
Don't worry about the next guy. Worry about your own work. If it gives the customer a great finished product and either lives or outlives it's warranty, use what delivers what you promise.
And if you're the one who is still in business when that roof needs to be replaced, more work for you which ='s mo' $. :)
Again, all as long as you give them a great job and provide what you promise.
As long as you follow the spec, you're in the clear liability-wise.
Good luck.
March 21, 2010 at 1:13 p.m.
WildBill
thanks for the replies...I can now say for sure that it will be a problem the next time the project is reroofed...I think I will see what the shingle manufacturer's position is on this before I bring it up to the Arch.
