Taking bids on Chimney Job
June 6, 2013 at 8:21 p.m.
Anyone want an easy chimney job? All you gotta do is take off the furnace stack cover, then the chimney cap,all the trim boards, all the siding all the way to the ground, all the plywood decking around the chimney, repair the years worth of rot to the inside of the chimney box, replace the two middle rafters in behind the chimney, put new plywood decking in, build a cricket, install I/W, new flashing with kickouts on both sides at the bottom, all new siding from the ground up, new trim boards, paint the new siding, install a new chimney cap and re-shingle.
Piece of Cake!
How much would you charge Labor and Materials?
June 14, 2013 at 5:08 a.m.
He will probably build the cricket right over the sag.
The sagging is MUCH worse in person. It's hard to get a good pic of unlevelness!
She won't call me for several years when the whole thing caves in!
:woohoo:
June 13, 2013 at 5:12 a.m.
The way the roof sags behind it indicates a real fun repair in the works! :laugh: You'll have to raise your price when the buddy finishes wrecking it, or gets fired when he tells her he needs $5K more, or just walking away from it. B)
June 12, 2013 at 8:26 p.m.
She called me back today stating that she felt so comfortable with me and my abilities/experience and that i just seemed so honest/knowledgeable and that she will refer me to others based on that alone with no work being performed.
H O W E V E R,
Her husband's cousin in law's buddy came over and cut his own throat giving a price of $1,650. :woohoo:
I hate it for her.
A crappy job's not worth even $16.50!
June 11, 2013 at 6:06 p.m.
She called back today and said they could not spend $3,500 but was there something I could do to stop the leaking and then they would worry about the cosmetic issues later.
Of course all the flashing and roof work has to be done and the right and backsides of the chimney as far as new siding.
But the cap is not leaking and the painting can wait a while.
Working on her newly revised quote later tonight!
June 8, 2013 at 8:55 p.m.
It was boxed in with an aluminum faced insulation board. I think that probably saved the inside of the chimney box.
June 7, 2013 at 6:03 p.m.
I bid it at $3,500 but if it comes in i may end up wishing that I gave Twill's bid! :blink:
Like GSD, I've only done a handful with this amount of extensive damage. The reason the damage becomes so bad is because either they can't afford to fix it or just don't want to spend that much.
When they first called I looked up the address on the satellite imagery which is about 2 yrs old and there was a blue tarp covering the whole chimney even back then.
This lady had 6 or 7 large pots and pans inside and outside the chimney full to the top with nasty water. :woohoo:
June 6, 2013 at 10:11 p.m.
GSD
I have bid so many of these through the years,, never got one of them. But I wouldn't do it for any cheaper than the price I gave.
Never did go see how any of them turned out either.
I have too much other stuff to do.
TAMKO - StormFighterFLEX August - Banner Ad - En Espanol
