Roof coatings
November 20, 2008 at 3:10 a.m.
Vickie the Boss at the WSRCA
Hello everyone. I'm trying to learn more about what to expect adding roof coating services to my business. Mostly flat smooth SBS type roofs. Equipment, labor budgets, restrictions, etc. Thanks in advance.>>>
February 11, 2013 at 10:33 a.m.
If a local contractor that must promote a material only warranty, or conklin doesn't inspect warranted roof systems, is any indication of the company as a whole, I'd have no use for them.
February 3, 2013 at 4:26 a.m.
kuzelka
Actually it is being used in New Zealand and Australia. We have done many roofs in Florida, Iowa, Chicago, St. Louis and more with the product. If buying it in bulk the cost drops to $85 a gallon. We have used it on every roof type out there. But you are definately right. If it's not applied right, just like everything else it will fail. The nice part for our customers are the tax breaks for the product and incentives. For example in Florida Let's say we do an install at $4 Sq ft. The FP&L rebate drops it to $3.55, then depending on tax bracket, immediate deductions drops it to $3.25 and with 179D tax credit it drops it to $2.85 sq ft. And they back the warranty hands down. They even backed one that we applied incorrectly, just because we were new at applying it. Can't say enough about this company.
July 9, 2011 at 10:55 p.m.
aircorp
Hello
I had to sign up for this blog because I was so intriqued by the responses I read related to roof coatings.
I learned a lot from everyone. I was first going to use a coating called "Polarroof"; then "Sealofles" the "Koolcoat" and on and on and on.
I even looked at the "Final Flat Roof" website to see what they had to say.
Basically, I have 7600 sq ft of rubber on a quanset style roof with two flat roofs attached on each side. They leak, especially around the AC roof unit. I'm taking that off this week. The rubber is not sealed between the quonset roof curve and the flat roof. It is just expanded over the intersection. You can poke it and it will flex several inches.
My first thought was to put a metal roof over the structure. Frame it from the curved peak down to the parapet. Install two knee walls over the 12 foot wide flat roof. I received a lot of flack from people and contractors. It will leak, it will leak, it will leak. I have a metal roof over my head right now. It leaked the first month I put it on, but I located the improperly installed screws and haven't had a leak since.
OK, do I coat the rubber membrane which is black, make it white, repair the leaks around the old AC unit and along the parapet walls???
Or do I put a new roof on it. The dome does not leak a drop. The rubber is great on the dome. Shame to have to put metal over that.
Thanks John
April 6, 2011 at 11:34 a.m.
JET
WestcoatShane Said: quote/]JET Said:
WestcoatShane Said: TPO has not shown anyone any reason it can boast anything other than being the greatest rip off product in the 21st century. Tarp systems like it and old black rubber EPDM in the Pacific Northwest has done nothing but shrink, split, fracture and fail everywhere I look. Experiments in the industry without any real proved track record for the region has done nothing but steal money from honest ( I use that word loosely) business owners. Asphalt roofs have always been the best roofs to use the only down turn for those manby pamby roofers is its hot and dirty. Spoiled roofers who dont like to get icky push that clean heat welded tarp membrane and I hate seeing it. Hot tar the roof and after a few years preserve it with the old and tried and true asphalt emulsion. Just about every Fred Meyers has done this and there roofs decades later has yet to need to be removed.
Sorry but I disagree.......btw, how many tpo, pvc, or epdm roofs have you installed?
JET
Jet, I dont have to rub crap on my face to know it doesnt make me look younger. We looked into the Tarp systems and saw TPO was failing all over the place. PVC at least looks like it is working out there. I have been on many TPO roofs and seen the same thing, stress cracks, splitting, shrinking, hardened materials and most of all caulking failures. It is a matter of time for TPO to head where all my TP goes, down the toilet. I feel bad for all those business owners who got suckered into buying that crap. The NRCA doesnt support it, and if you Google TPO failures you better pack a lunch because you got a great deal of reading to do.
Just answer the question and then I'll decide if your opinion matters..........deal?
JET http://www.rooferscoffeeshop.com/rcs/users/JET/
April 5, 2011 at 8:17 p.m.
glassemulsion
Okay here it is, tpo,pvc,hbu,torch,coatings, whatever it is companies spend millions of dollars to make a roof system that is better than the next guys, installed properly any of them should last. with that said, here is the real problem the Warranty! What roofers don't back there roofs anymore its all done through the manufacture? That's not saying much for the roofing co. Any shit ball roof will last two years. If these roofer installing these roofs thought they were so great why only two years of warranty. We give 5-10 and 15 year warranty's from my co. Because I believe in my system. The question is do you!
April 5, 2011 at 2:34 p.m.
WestcoatShane
JET
Jet, I dont have to rub crap on my face to know it doesn't make me look younger. We looked into the Tarp systems and saw TPO was failing all over the place. PVC at least looks like it is working out there. I have been on many TPO roofs and seen the same thing, stress cracks, splitting, shrinking, hardened materials and most of all caulking failures. It is a matter of time for TPO to head where all my TP goes, down the toilet. I feel bad for all those business owners who got suckered into buying that crap. The NRCA doesn't support it, and if you Google TPO failures you better pack a lunch because you got a great deal of reading to do.
March 25, 2011 at 8:15 p.m.
Sensational
Roof Coatings are NOT a new roof. They do however have a place for extending the life of an existing roof. If the existing roof is prepped properly and the appropriate material is used, you can have a successful project. Since I have held positions at the contractor, distributor, and manufacture's levels, I tend to only support coating metal roofs. Just one guy's opinion.
March 24, 2011 at 11:42 a.m.
JET
JET
March 24, 2011 at 11:41 a.m.
JET
Mike H Said:
JET Said: Weve got about two million square feet of Stevens TPO that is now showing stress cracks around skylights, etc. Talked to the ER rep and hes sending out some info for us to look at. Now that DOW is out of the single-ply business the Stevens issue is dead which is bad. Im hoping my distributor will step up with some assistance but Im not holding my breath.
JET
I just hate it when my wife does this to me, but I cant resist. Its that Silver Spoon thing.
[size=5]I told ya so.[/size]
:blush: :blink: :silly: :woohoo:
PS, to stay on topic, Conklin is, or at least it used to be, sold like Amway. Network. Its the product a lot of the Amish/Mennonite use around here and youll see one guy sell it, and another guy put it on if the seller is too busy.
Guess I missed this reply Mike.........refresh my memory on what you told me.
JET
March 21, 2011 at 4:02 p.m.
WestcoatShane
TPO has not shown anyone any reason it can boast anything other than being the greatest rip off product in the 21st century. Tarp systems like it and old black rubber EPDM in the Pacific Northwest has done nothing but shrink, split, fracture and fail everywhere I look. Experiments in the industry without any real proved track record for the region has done nothing but steal money from honest ( I use that word loosely) business owners. Asphalt roofs have always been the best roofs to use the only down turn for those manby pamby roofers is its hot and dirty. Spoiled roofers who don't like to get icky push that clean heat welded tarp membrane and I hate seeing it. Hot tar the roof and after a few years preserve it with the old and tried and true asphalt emulsion. Just about every Fred Meyers has done this and there roofs decades later has yet to need to be removed.
January 28, 2011 at 8:39 p.m.
IF thats true then Ive never seen it, and if its true then the consequences are far less than the consequences of stress cracks on a single ply which is at worst an immediate leak and at best a potential one (which quickly becomes imminent). The crack in the SPF will take years for a leak to develop and if the re-coat programme was implemented then the effects of the crack will be negated when the re-coat is applied. Never seen SPF applied to a steel deck either. How do you eliminate the telegraphing?" I've seen it done.they first mechanically attach insulation boards to the steel deck then apply SPF.Cracks develop at the joints of insulation.maybe they should apply two layers of insulation and stagger the joints.
January 27, 2011 at 10:46 p.m.
Roofer girl
There are systems that will work on tar and gravel or BUR. The key is in the preparation and the costs I am seeing quoted here seem very high. Of course that is all a realative term depending on the region you are working in. I would recommend that if you are interested in a coating system. Check with your local supply companies and have them put you in touch with the coating reps. Any good supplier should be able to do this. Make sure you are getting the proper coating for the job ansee if the technical rep for the company will come out on your first job. It is really easy to take a one day training and know the basics, but what roof especially a flat one is basic. A quality job is done in the details and the preparation.
Don't discount the possibilities, you can make these products very profitable for yourself and save building owners money and the hassle and disruption of a complete tear off.
January 27, 2011 at 4:08 p.m.
JET
I just hate it when my wife does this to me, but I can't resist. It's that Silver Spoon thing.
PS, to stay on topic, Conklin is, or at least it used to be, sold like Amway. Network. It's the product a lot of the Amish/Mennonite use around here and you'll see one guy sell it, and another guy put it on if the seller is too busy.
January 27, 2011 at 2:48 p.m.
elcid
There is a lot to be said in favor of dead level roofs. We installed a number of them which were all successful installations. There is no secret - just use the right specification, which is coal tar applications. Advantages are quickly recognized on large installations, where the HVAC designer can reduce the space volumes appreciably, and the plumbing engineer can now install much smaller rainwater conductors to the mains. Furthermore , water on roof will certainly reduce a/c required. However, structual designer must account for this increased load in his deck design, Basic problem to date is the fact that anything other than pitch is bound to fail.
January 24, 2011 at 6:27 a.m.
FL Roofer
Alba Said: SPF develops stress cracks too.especially when applied over steel decks.
IF thats true then I've never seen it, and if it's true then the consequences are far less than the consequences of stress cracks on a single ply which is at worst an immediate leak and at best a potential one (which quickly becomes imminent). The crack in the SPF will take years for a leak to develop and if the re-coat programme was implemented then the effects of the crack will be negated when the re-coat is applied. Never seen SPF applied to a steel deck either. How do you eliminate the "telegraphing"?
