Question of the month
« Back To Question Of The Month
May 23, 2010 at 1:01 a.m.
dutchboy6804
Why is lead installed at interior drains on flat roofs?
July 7, 2010 at 5:01 p.m.
Al Gores Fat Arse would be a great replacement. B) ;) ;) B)
July 7, 2010 at 2:37 p.m.
Colpaw
We are a small outfit in Northern Virginia that installs mostly low slope asphalt systems. I've always wondered what the "green" folks would say about all the run off from large roof systems that passes over the lead in asphalt roof systems! I would love to come up with a replacement for lead flashing in drains that would "save the world!"
June 14, 2010 at 2:43 p.m.
jimAKAblue
can we get a new question of the month? Its June now.
June 1, 2010 at 12:27 a.m.
Drain is a very critical point of the roof.No matter how good the roofer the felt always ends up being sliced to fit the slump.Putting a sheet of lead ensures that water won't penetrate through the slices. Another question to ponder.If and when this recession ends do you guys think that there will be a bigger shortage of experienced roofers than before the recession?I've met some laid off roofers who now have either found other trades or feel too out of shape to get back on the roofs.
May 23, 2010 at 5:20 p.m.
The FNRUFR
I asked this same question a few years back. It's for BUR type roofing systems its a flashing of sorts to transition threw the sump to drain "target" forming a compression fit when drain ring is properly install.
