Preferred method for installing APP and SBS
« Back To RCS Lunch & Learn
June 26, 2023 at 4:21 p.m.
laurenwhite
Jacob Heaps from Johns Manville talks about all things modified bitumen. What is your preferred method of installation for APP or SBS?
The RCS Lunch & Learn webinar series is dedicated to helping educate and inform about products, services and much more. It is an educational opportunity for the roofing industry as only RoofersCoffeeShop can do.
December 21, 2023 at 10:50 p.m.
changbennett
In the torch-applied method, modified bitumen sheets are typically rolled out over the roof surface, and a super mario bros wondertorch is used to heat the underside of the membrane. The melted bitumen on the bottom bonds with the substrate.
August 29, 2023 at 9:40 p.m.
Annata20
Heat welding can be used to install modified bitumen membranes made of atactic polypropylene (APP) and styrene-butadiene styrene (SBS), either over an open flame with a specialized propane roofing torch or with a hot air welding equipment.
