Not Giving My Best?
July 10, 2013 at 3:43 p.m.
I'm accused of not giving my best when I use ABS/Plastic Tower pipe collars instead of lead. I also offer Copper in case you're wondering, but I charge more since they're custom made. I double boot the plastic ones and expect 20 years, at which time a new cover could be slipped over the pipe if necessary.
I looked for a leak near this pipe collar on a 4-5 year old roof.
Must be wind damage. :) :woohoo:
July 15, 2013 at 12:52 p.m.
DdubyaC Said: My problem all of a sudden about three years ago has been squirrels. Painting them with enamel has fixed that.
Double boot eh? Thats not a bad idea. More for my shingle roofs but not your 100yr beauties. Ive wondered if you could paint or coat the plastic boots with something reflective to get more life.
Like the others here, I spray the inside and outside of my collars with silacone and also spray the pipe so the act of stretching the rubber is less traumatic to the collar. :)
July 14, 2013 at 8:44 p.m.
" I don't care for planned obsolescence when it is used on me so I have to apply the Golden Rule with it. I'm all in favor of Tinner's policy, but I'd be absolutely sure the homeowner grasped the full impact of the choice being offered." Different prices for each option and an explanation. Also the fact that slate roofs that don't have sleepers under the hips and ridges will need periodic re-pointing. During these 3-5 year inspections and maintenance, I find these toweer boots witht he tops sometimes splitting. I just recover the top with a new gasket and add a couple of dollars like I would a slate replacement. No need to ever find one leaking. Full disclosure each time.
July 14, 2013 at 2:37 p.m.
A properly painted all steel jack with the material installed so it doesn't trap debris will last longer than any roof except slate unless it's getting constantly doused with corrosives. Having a plumbing jack that moves independently from the pipe is a must. You can make your own counterflash rings for any diameter pipe out of flat sheet in seconds if you have some templates on hand. I make my templates out of #15 felt so they store in any tiny space. One rivet or zip screw, two if you are feeling insecure. There is no reason to use neoprene or plastic on anything unless you just want a guaranteed cake-walk repair you can bill for in about ten years. I don't care for planned obsolescence when it is used on me so I have to apply the Golden Rule with it. I'm all in favor of Tinner's policy, but I'd be absolutely sure the homeowner grasped the full impact of the choice being offered.
July 13, 2013 at 6:12 a.m.
copperman Said: there is no wind damage at all. All I see are teeth marks in the lead.
:) I was just being facetious. Squirrels ate it. They're terrible about it here. :lol:
July 13, 2013 at 12:13 a.m.
tinner, do you ever work on any roofs that aren't steep and high? :dry:
July 12, 2013 at 4:33 p.m.
July 11, 2013 at 8:42 p.m.
Double boot eh? Thats not a bad idea. More for my shingle roofs but not your 100yr beauties. I've wondered if you could paint or coat the plastic boots with something reflective to get more life.
July 11, 2013 at 6:54 a.m.
GSD
I see it all the time.
July 10, 2013 at 4:55 p.m.
Squirrels love lead pipe flashing's. I had them chew them all the time. They would even go after solder joints
