GAf granual Mod Bit tourchdown vs EPDM
March 29, 2013 at 1:07 p.m.
joebos2
any thoughts on comparing these two approaches for flat roof application?
current install is liberty is being laid over tapered ISO followed by GAF rubberoid granualar MOD Bit.
do i understand manuf onthis is 12 years?
How does this stack up against .060 EPDM ?
Joe Wiso
April 17, 2013 at 10:30 p.m.
MJTCOINC
Use fully adhered 0.60 EPDM right on taper ISO .Its much better -no base sheet . If You know specs and details you can get the 20 years warranty easily.
April 10, 2013 at 2:58 p.m.
builderr
Im not sure about specific manufacturer's and warranties, but, in general, if you apply a fully adhered base sheet over a nailable base sheet, you can increase the warranty from 10 to 15 years. as far as adhering a base sheet to an iso panel, Im not sure about the spercifics....it needs a nailable base to install a nailable base sheet, unless the ISO has a base sheet already on it, which Im sure someone makes...
hope this helps, and that my info is current....
