Counter flashing....
December 14, 2008 at 3:46 a.m.
manbearpig
I got a flashing job to do and the customer wants me to run the counter flashing like what I call a "Band-Aid".
It's a 4/12 roof......at most, that runs into a brick wall. The counter flashing now is stepped and in mortar joint but is cheap aluminum t>>>
December 10, 2011 at 9:07 p.m.
SuzyQRoofer
Here is a video showing excellent craftsmanship. The fabrication and installation of the copper chimney flashings are spot on. Check it out. http://www.youtube.com/watch?v=7bONgeVLqt4
January 1, 2009 at 9:35 a.m.
Pot Gregory
Hay John , do you charge by the foot, or do it by the job when pricing. For me .....New-$15@ Ft......Tearout and replace $30 @ Ft. This is with Aluminum Trim Coil. When using copper, which I use very little of , I double the price ,if not more.>>>
December 27, 2008 at 9:01 p.m.
mortilandan
that there copper must of cost a pretty pennie, the only time i've ever used copper for counter flasing is with ceader shake, that's it the rest get metal.3 1/2" on the deck and 6" up the wall. Anyways if the customer wants to pay for copper so be it.>>>
December 26, 2008 at 5:02 p.m.
mortilandan
Just make a bend @ the top around 3/8" at a 45 degree then rund a bead of chalking, and then Bobs your uncle.>>>
December 25, 2008 at 7:45 p.m.
Emeril Lagasse
That is what I use, we call them "masonry Anchors". Don't us them in my counter flashing though. Most of the time I use a 24ga. one piece reglet metal, painted enamble. I go with the color black as my standard color. My favorite caulk is "Rainbust>>>
December 25, 2008 at 5:56 p.m.
manbearpig
These?>>>
December 25, 2008 at 5:19 p.m.
RABOIN
We have called them "thunder nails" on occasion too. A stainless steel drive pin that drives into a lead insert. The insert is a 1/4 inch and the drive pin expands it as it goes in and holds the insert into the hole. Very strong and quick.>>>
December 25, 2008 at 2:39 p.m.
manbearpig
TRG, Thanks for putting up with my questions. Where do you guys get 1/8 x 1" lead molys? I know this is gonna sound bad.....but I have never heard of a lead moly. Do they call them anything else? How do they install....do you drill then hammer them into>>>
December 25, 2008 at 4:28 a.m.
mortilandan
Merry Xmas Randy. well when it comes to flasing, it's all cosmetic, when it's brick steped it looks better that's for sure.You'll save yourself alot of timie if you could just slap it in, if you have a pair of thoughs, just give it a 45 degee bend at>>>
December 25, 2008 at 2:43 a.m.
manbearpig
TRG....I like how that copper looks! I do have a question for you all though. On your chimney I noticed you didnt have to put fasteners down low, that looks nice. But in my application, I am going to be running 45' up a wall and I need to fasten my cou>>>
December 15, 2008 at 11:24 a.m.
jfreynik
That flashing looks great but if you really want it to look good for life use dark bronze color caulk. the copper will turn that color in a few months and it will blend perfect>>>
December 15, 2008 at 3:40 a.m.
RABOIN
If you cut into the mortar joint or a straight line right up the roof, it only has to be about a thick saw blade wide. Maybe a 1/4 inch total width. When you bend the metal to insert into that cut line, you bend a 90 degree bend and then bend the back s>>>
December 15, 2008 at 2:35 a.m.
robert
Lead anchor drive pins,use them all the time, fast and easy secure finish!>>>
December 15, 2008 at 1:34 a.m.
jamieu
I use masonary nails to attach c.f. to the riglet. I like the round ones but sometimes the wedges work well too. you can also make your own wedges out of scrap pieces of aluminum. the inspectors around here like to see 8" minimum between the c.f. and>>>
December 14, 2008 at 7:46 p.m.
manbearpig
Jedd, That is similar to how I have done it before, minus the rolled lead plugs. Where do you guys get rolled lead plugs?
I seen a reglet system that lets me cut a groove, install my c/f then use what it called an EPDM plug. I liked how that looked, oth>>>
