Concrete spikes (Rawls)
October 2, 2013 at 9:49 a.m.
JCAP14
Any suggestions on removing Spikes quickly (cutting heads off) counter-sunk with iso plate, can't really get to shank of spike.. electric bolt cutters ??
October 7, 2013 at 3:31 p.m.
We usually drill them out
October 4, 2013 at 5:06 a.m.
liroofer
This is what I recommend.
October 3, 2013 at 4:26 p.m.
liroofer
In the past, I have used a pick axe, with about a three foot handle. It might also be called a "Maddox", or something similar to that.
Use the flat end. You give it a good swing and they chop right off.
You may be able to chop them right through the insulation, depends on what type of insulation.
