Changing manufacturers
April 15, 2022 at 11:46 a.m.
laurenwhite
Have you changed manufacturers due to material shortages/supply chain issues? If you have switched, will you go back to your original manufacturer?
May 29, 2022 at 7:27 p.m.
clarkleblanc
It will be possible if the primary supplier meets the eligibility and proposed requirements. And the problem is that I had a good cooperation relationship with them before. You should still go back. And if the work is more developed, you can choose both new and old suppliers if they are suitable.
